Hi everyone, as the title says, i'm looking to upgrade my socket 939 system and I could use a little advice.
Current sytem is:
AMD 64 x2 4200+ (2.2 Ghz)
MSI K8N SLI Platinum
XFX Geforce 8800 GTS (320MB)
2x1 GB Corsair PC3200
OZTech StealthXStream 600W
Maxtor SATA 80GB
Windows XP
I've just posted the guts of the system, everything else is either easy for me to decide on or not in need of an upgrade. Its use is mainly for casual gaming, watching streams and general web use.
I've had this system for quite some time now, the GFX card and the PSU are the youngest components and I would like to keep them for the new system if possible (will the 8800GTS last a bit longer on a better system?)
I'd like to play most games at a good graphics level without the system struggling, at the moment I think its my processor that is the bottleneck and possibly the Motherboard?
I've researched as much as I can but i'm still unsure what to get. I would like to avoid spending a lot of money but at the same time i'm not against spending money on parts that will last that bit longer.
The Phenom II X3 720 BE (AM3) on an AM3 board seems to be a good starting point, i'm assuming socket AM3 should be around for a couple of years? and if I wanted to, I could upgrade to a more powerful processor later on.
The motherboard is the part that i'm unsure about, should I spend a lot on a good MB? I'm hoping that if I was to do this, it would last me a bit longer.
I'm open to and would appreciate any advice!
Current sytem is:
Maxtor SATA 80GB
Windows XP
and you wont see much performance increase upgrading the CPU for gaming. The graphics card is all you need to upgrade.
