Upgrade from Sandy?
14 Sep 2008
Peterborough
Is there any real reason for me to upgrade my current setup? Running 2500k @ 4.4GHz (can go higher but this is a nice low voltage OC). From what little benchies I've seen, there's been barely any speed improvement these last.. 4? generations, but I'm open to more input :)
None.
If you need USB3 you can get a controller card, DDR4 is pointless and you'll likely run into bugs with a new platform right now so it's actually a net loss.
If you can do a cheap upgrade to a good clocking 2700K, might net you a few FPS with that CF setup or do a complete jump to a juicy hex core X99
It depends what your looking from in an upgrade, I went from a 2600k to my 5960x and the difference for me is big enough for me to be happy. Plus I got the 5960X new at a big discount :)
Did you see this?
I'd imagine the difference would be even larger with the 2 x Fury-x in your sig.
Strange. This is the only test I have seen that makes the 6700K actually not completely pointless. Every other review shows that haswell is as fast, sometimes actually faster than skylake in gaming.
WTH?
At the moment the x99 5820k is the best choice on the market, pretty much the same price as skylake and just better overall. Intel made a mistake when pricing this cpu as it's the best bang for buck by miles
Agreed completely. I would have got the 5820k but chose the 5960x as I knew the seller and got a massive discount off and new :)
Sandy's still dandy.
It sure is. I was convinced that skylake was going to be a massive upgrade in performance from my 2600k. I'd even spoken to the finance dept (wife) and secured funding for an upgrade :)
Looks like I'll be sticking with my 2600k and Z77 board for a while longer. Just wish it had more than 2 intel sata 3 slots though as I've got 3 SSDs and one is stuck in the asmedia slot which is slower than the intel ones. I also recently bought a GTX980 ti to help my gaming so it's not all bad.
You can always drop a 3770k in there if you get the itch.
The only real reason to upgrade is for chipped features of pcie lanes.
