Upgrade from stock Intel cooler
21 Jul 2014
southampton
Hi I have a stock Intel cooler on my new rig that I just purchased from oc. I want to upgrade preferably sticking to a black and white theme. Can anybody recommend me a cooler.
I'm not going to overclock not to fussed about water but don't want to speed a lot £40 maybe £50 tops
Thanks matt
Nice. You don't need to spend all that much to cool that CPU. This one caught my eye for your black/white theme but comes with a question mark:
My basket at Overclockers UK:
The Raijintek is 157mm tall. The max CPU cooler height on the Kolink Luminosity is stated to be 155mm. Given that case manufacturers tend to add around 5mm to such dimensions, just to cover a little excess, it would probably fit. But I would ask OcUK if they know it will.
Or just pick another under 155mm. Even a £15-20 cooler will be fine.
