Upgrade help needed
15 Jul 2012
Hello everyone
I need some serious help here are my issues
Bad case - Cit mars gaming case - bad cooling and too small I think
Amd 965be x4 - Runs at 65/66c when playing Gw2 - Case can't fit bigger fan
M3a ucc Motherboard - Thinking of changing to a intel cpu
So here is where I need help, I am thinking of buying a new:
1/ Case
2/ cpu for gaming - so suggestions of products would be good
3/Motherboard that can handle intel cpu's
4/possible aftermarket fan, if the intel one is too noisy
I have a budget of £300-350, I have several things also Can I move all parts in current system to a new system? will I have to reboot windows? how easy is it to do what I want to do. any help would be amazing.
Edit: thanks for all the suggestions think I have some tough choices to make
Firstly welcome,
Your right, your case is poor. What PSU do you have? What GPU do you run?
My suggestions would be:
3570k: £185
Z77 dh3: £83
Corsair 300r: £60
Coolermaster 612s: £32
A tad over but worth it.
Firstly welcome,
3570k: £185
Z77 dh3: £83
Corsair 300r: £60
My psu is a oc'z 650 watt and my gpu is a gtx 560ti.. I have a lot of people recommend the coolmaster haf towers.
The HAF's do have good airflow, but they are expensive and not the best looking. a lot of other cases, including the ones we specced have good cooling and other features, while being more affordable.
I don't think the HAF 912 was that well reveiewed.
Thanks, also I have never built a pc before nor removed parts from one. Is it easy/hard? what order to you put the parts in?
Decided to push the budget to £400...
Ok I have decided to go for the stock cooler can upgrade later and heard its not to bad :)
So its just a gaming case, Cpu, Motherboard and I was thinking maybe some new ram. so any final spec suggestions would be great guys.
With heatsink
if you dont like white case, the black / red is due in soon. could wait for it
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £184.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £81.98
1 x Aerocool Xpredator X1 Midi Tower Case - White/Black £49.99
1 x Xigmatek Dark Knight SD-1283 Night Hawk Edition CPU Cooler (Socket LGA 2011/1366/1156/1155/775 and AMD FM1/AM3/AM2+/AM2) £34.99
1 x Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) £29.99
Total : £395.45 (includes shipping : £11.25).
P.S theres lots of tut videos online that will help you build
if you get stuck post here and we will help
There are ways to fiddle it so you dont need to. but i would. will save you hassle in future
+ fresh install on new machine will feel awesome :)
just backup data in preperation
