Upgrade Help Please
Suspended
1 May 2008
Sunny Llandudno
Birthday in 10 days, *Cough Happy Birthday Thread Cough*
Pc upgrade time, any suggestions on what i should do?
My current system
Cpu-Amd 64 X 4800+
Motherboard-Asus M2N-MX
RAM-Kingston 2GB 5300
GFX-Using onboard graphics from motherboard
HDD-Samsung Spinpoint F1 500GB
My questions are
Does anyone know how good my CPU is for clocking, because if its good I'll stick a cooler on it and have a blast.
Of course i need a new graphics card any suggestions?
Does my RAM need upgrading, or is it sufficient?
Budget is £150-175
^^ Don't really want to blow it on one part though
Kind Regard & Thanks in Advance
Ben
Something like these parts might do you, from what I can tell the cooler should allow the CPU some breathing room and the graphics card is an enormous step up from onboard as well as being a bit of a bargain really. You could however consider waiting another month or so to see what the new graphics card releases offer in terms of new options/price reductions.
OcUK GeForce 8800 GT 512MB GDDR3 HDTV/DVI (PCI-Express) - Retail £94.99
(£111.61) £94.99
(£111.61)
Arctic Cooling Freezer 64 Pro PWM CPU Cooler (Socket 754/939/940/AM2) £11.99
(£14.09) £11.99
(£14.09)
Sub Total : £106.98
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.25
VAT is being charged at 17.5% VAT : £20.17
Total : £135.40
Watercooling to me just adds another layer of complications but it is effective if you want quieter systems (don't get a noisy pump obviously), I'm not sure that it is hugely below good air cooling in temperature terms though.
If the 9600 is a 9600GT then it wouldn't be a bad option but you'd need someone elses advice on the intricacies of watercooling I'm afraid.
Adding watercooling would turn the 'upgrade' into a 'project'.
A decent setup would likely cost a minimum of £200 and a good few hours of your time.
Seen a Zalman set on another website, its "Silent".
XFX 9600GT 512MB GDDR3 650MHz Dual DVI HDCP HDTV out PCI-E Graphics Card
Yeah its a GT :)
Yeah, the 'Reserator' I'm guessing.
Passive watercooling, so not the best performance but very quiet. Only the noise of your case fans and the pump.
Yes its a Zalman RESERATOR1-PLUS Fanless Water Cooling System
Two questions, is the Xfx 9600gt the best card i'm going to get <£100?
And is the watercooling system mentioned above any good?
