Upgrade help please
11 Oct 2011
Birmingham
hi all.. and hello again..
with The elder scrolls online out and a few others on the way IE watchdogs etc :eek:
i think its around the time where i thin i need a few new parts
parts i have now i can sell of
money around £800 maybe alittle more
so what i really need is a new case the one i have now is a Zulaman z9 plus
and a SSD as i still have a SATA around 300-500g needed no use for a second HDD
would also like to go water cooling as dust is started to get to me :P
anyway what i have now are as follows
MSI ATI Radeon HD 6950 OC Twin FrozR III Power Edition 2048MB GDDR5 PCI-Express Graphics
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
Gigabyte Z68XP-UD3 Intel Z68 (Socket 1155) DDR3 Motherboard Seagate
Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache - OEM (ST31000524AS) HDD
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel
Corsair A70 High-Performance Dual Fan CPU Cooler (Socket AM2/AM3/LGA775/LGA1155/LGA1156/LGA1366/LGA2011)
all brought from overclockers
Order Date: 14 Oct, 11, 6:49 am <---- so yea alittle old now and somewhat dated :D
forgot to say i also have
OCZ StealthXStream 2 600W Power Supply
thank you for any help
PS if there is things/thing i could keep then im happy to keep ie MOBO etc ram but if u feel they would be better replaced then thats ok
what about then just a new GPU maybe more ram and a better Processor ?
having trouble playing elder scrolls online and med/max settings!
also a SSD.. sata getting old now :(
RAM and processor are fine..like I said a new GPU would make a big difference, R9 280/280X would be a nice upgrade. Yes check out the Samsung 120GB 840 Evo SSD or 250GB. Also you should overclock the processor to get more out of it, you have a capable cooler so why not
is there a program i could use to overclock it
also been looking at my Mobo and bios drivers should i update my bios to UEFI
u got a card that would be nice i know some cards arent as good as others etc
dont want to get the wrong one really :P
can anyone advise me what gpu to get and SSD please really dont want to get the wrong one..
like 270 or 290 etc..
thank you
Or the next level up
Sapphire Radeon R9 290 Tri-X 4096MB £319
The samsung 250 gig SSd as detailed above.
Why do you want to change the Zalman Z9?? Its a great case with plenty of room and loads of fan cooling options. Do you need a full tower case?
Overclocking is best done in the bios. Just up the multiplier 2 shots (say from 33 to 35) until it wont boot and then either back it off 1 or add more voltage and keep going. 1.3 volts on the core seems to be enough to get 4.5 gig on these chips and that will give you a huge boost to your machine.
Antec Kúhler H2O 1220 Series 4 High Performance Liquid CPU Cooler £81:60
Should fit in the top and will cool better than your A70 cooler. You could also add
Corsair SP120 Performance Series High Pressure - Dual Pack £22.00
To improve the cooling of the 1220 and stick both fans on the fan controller built into the case to control them as they are not silent at full speed.
Total of £550:58 inc £8 postage.
so i brought the
it dont fit in the Zulaman z9 case, i had to bend the HDD holder to get it in :P
while using the GPU in hdmi more i only get 60 Hertz
but my moniter supports 144 Hertz can i not use 144 while using a hdmi
or do i have to use dvi to get the 144
thank you
ok really need help here brought all of the above..
first the gpu didnt fit i needed to take out the HDD clips which now my hdds wont stay in place.. but hey the gpu is in
second i dont think i hsve anywhere to put the ssd
third the antec kuhler1220 cooler i got plus the 2 fans will not fit in the zulaman z9 case as the ram/memory is in the way..
as it stands the z9 is small compared to the cooler..
really recking my brain here i thought it was me not putted it in right
even the back of the z9 case didnt have enough room for the back plate for the cooler :( (the bit that open that shows u the back of the mobo)
should be able to upload some pics if it would help...
well i have tryed everything to get the cooler into the zulaman z9 case with no luck im just going to say its far to small for the gpu and the water cooler
anyway
can someone please point me to a case that would fit both
i dont have much moneys left as it cost me 600 for the stuff i already go
i prob could strech to £60 for a new case not sure
really need one that would fit my gpu and cooler no point in having then if i cant use them
thank you
Here are four that apparently will do the job for around that budget, according to a compatibility check with a H100i, which has the same dimensions as the Kuhler H20 1220. They all have a roof compartment, or raised fan grills, to allow top rad fitting, other than the Ronin, which has a high ceiling area and therefore also works in that respect. However, I suggest you ask OcUK to confirm if the cooler and GPU will fit before ordering whichever case you decide on. :)
YOUR BASKET
1 x BitFenix Ronin Tower Case - Black £69.95
1 x NZXT Phantom 240 Midi-Tower - White £65.99
1 x Antec GX 700 Rugged Gaming Case £59.99
1 x Antec GX500 Midi-Tower - Black £43.99
Total : £266.86 (includes shipping : £22.45).
There's probably a few more for close to that budget that have slipped my mind.
* The GX 700 may have a problem with the GPU length.
The Carbide 300R can sometimes fit a H100i, depending on motherboard and RAM:
YOUR BASKET
1 x Corsair Carbide 300R Mid Tower Case - Black (CC-9011014-WW) £59.99
looking at them cases it looks like the cooler wont fit
the motherboard sits at the top of the case and the ram is close to the cpu
the ram its self sits to the top of the case and sticks out quite abit
im so stressed :(
