upgrade help pls
2 Jan 2015
newbie village scotland
looking to upgrade my pc used for gaming media etc.any help apprieciated.
my specs are..
cpu i5 [email protected] with noctua tower cooler twin 85mmfans
ram 8gb ddr3@1600mhz
motherboard maximus iv gene-z/gen3{lga1155}
gpu msi twin fozer 3 7950
storage 59gb ssd,298 hdd,1tb usb hdd
psu corsair tx650m
I thought I might just replace the gpu not sure maybe a r9 380 and another ssd
I might have about 500 to spend.thanks bob
Thanks the 390 should fit as it states..
Supports graphic card up to 350mm in length with one HDD mounted
Supports graphic card up to 210mm in length with two/three HDD mounted
Unless you have two/three HDD mounted.
