I'd normally ask exactly what you do with your PC but I'll assume general gaming. In which case I'd buy the parts below with an ASRock DUAL-VSTA motherboard so that you can re-use your existing Ram as your budget isn't enough to replace the motherboard with a good overclocking one and get DDR2 Ram.
Sapphire ATI Radeon X1950 Pro 256MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £107.99
(£126.89) £107.99
(£126.89)
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail £105.99
(£124.54) £105.99
(£124.54)
Sub Total : £213.98
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.25
Vat : £38.89
Total : £261.12
What sort of level of graphics power would you be happy with on the PC then? To maintain the same level as the 6800gt would cost around £80ish which is almost a third of the budget, you would also need Ram if you buy most new motherboards as they accept DDR2 only (apart from the ASRock I suggested and one other I believe, also from ASRock) and to get 1gb is around £80 at present so you would end up with less Ram but a faster CPU.
