Hi all, I’m looking to upgrade/build a new rig hopefully salvaging some parts from my existing setup.
ASUS A8N-SLI Premium nForce4
AMD Athlon 64 X2 4800+@ 2400 MHz Toledo (JH-E6, 939)
2 x 1 GB OCZ ECM Platinum ( DDR-SDRAM PC-4000 (250 MHz) - [DDR-500] )
2 x 200 GB Samsung SP2004C HD SATA 2.0 (SATA 300)
1x300GB Maxtor HD (back up)
Corsair 620 HX PSU
XFX 7800gtx
2xLG Electronics L226W
PIONEER DVD-RW DVR-107D
SAMSUNG TSSTcorp CDDVDW SH-S203P
All housed in a Thermaltake Xaser case.
I built this rig, with a few tweaks here and there, 3-3.5 years ago and it’s really beginning to show its age, the CPU cores are tending to overheat, which results in a shutdown, so I suspect it’s on its way. Being out of the loop for 6 months these days can leave you lagging behind and so I’ve been more or less looking at some sort of bundle deal with a good GPU thrown in but tbh my head is fried with it all.
I use this rig mainly for sound production with some amateur video and animation in addition to some online gaming. (Would like to keep an eye on components noise lvl)
Will be running Win XP as most of the apps I use are 32 bit apps with a view to upgrading to vista at a later date when apps and CPU prices for high-end components drop. The Apps include Photo Shop, After Effects, Fraps, Premier Pro, Cubase, Pro tools, filters and resource hungry plug-ins. Finally, online gaming, EVE-Online is my preferred choice and would be nice to be ready for ambulation. Ideally I would be looking to squeeze maybe 1.5 to 2 years out of this new spec.
I’m not a big fan of nforce, however if I’m quoted an nforce board I would be grateful if the choice were explained. All in all though any help would be appreciated.
My budget is £400 but its elastic enough to stretch to £500ish.
Corsair 620 HX PSU
XFX 7800gtx
with their DLX results stats n read outs. Both Cob and W3bbo ran 8 GB of this kit stable in their rigs with no problems which seems as good a reason as any to pick it since I will be up grading to Vista sometime in the not too distant future and will need the 8 GB for the apps I use.
