Upgrade help
31 Aug 2006
This is my set up , given to me by my older brother £500 to spend or keep what i have , i am happy with the CPU at the mo
I have been think upgrading my 7800GTX for a better card
Logitech MX Revolution Advanced Cordless x2
Logitech Cordless G7
19 HannsG HGHW191 19" Widescreen TFT Monitor
Windows XP Pro
Hec 600W SLi PSU
FX 57 @ 3.0 Mhz
Asus A8N-SLi SE nForce4 SLi
2GB PC3200 400 DDR
7800 GTX 256
X2 160 STA 160 HD
CreativeLabs Sound Blaster X-Fi Fatal1ty FPS
To be honest there's nothing wrong with the rig you have. The 7800GTX is more than enough for a 19" TFT and really anything more will be wasted.
You could get a bigger screen such as a 22" widescreen and then with whats left get a better card but as i already said you have a pretty decent rig as it is.
agreed with the above post....sit tight wait a few months for :
a) vista
b) dx10
c) quad core cpus
if you spent any money on a gpu atm it would be a waste of money especially for the performance you see, unless you go SLI or XFIRE, which is still a waste if you wanna compare it to the 8800's.......
