Upgrade Help
7 Jul 2004
Gloucester
Needs to be sub £100 as I have next to no money right now!
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 £30
Gigabyte GA_945PL_S3 (Socket 775) PCI-Express DDR2 Motherboard -OEM £25
Now I need the best C2D cpu for under £50 - can be 1st or 2nd hand. What should I get? Also is this MB good for clocking as i'll be clocking this as much as air physically can? :)
The motherboard is unlikely to be fantastic for overclocking since the 945 chipset is low-mid range but for the price you aren't going to be able to do much better. You may find that it does rather better than I suspect anyway.
