- 27 Dec 2008
Right me Grandad will probably be on here later telling me off for questioning his advice but hey (I would have phoned you but its late).
Im upgrading my CPU from a Q6600 to hopefully another CPU what will go 4 years aswell.
I've got 500-600£ (i can go a touch more if its worth it)to spend on this upgrade which will consist of:
CPU
COOLER (im thinking water cooler)
MOBO
RAM
SSD Crucial RealSSD M4 64GB
I am completely out the loop with the latest gear.
I was all set to get this
Krypton Z68 600i Intel Core i5 2500K 3.30GHz @ 4.60GHz Overclocked Bundle Options applied to the above product:
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)
Asus P8Z68-V PRO Intel Z68 (Socket 1155) DDR3 Motherboard
Crucial RealSSD M4 64GB 2.5" SATA 6Gb/s Solid State Hard Drive
I then felt that i'm being a bit restricted on the products because there is faster ram availible better CPU's and coolers. All because i wanted OCuk to do the overclocking (which really i can do myself).
so ive done this list
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor RetailAsus P8Z68-V Intel Z68 (Socket 1155) DDR3 Motherboard Crucial RealSSD M464GB 2.5" SATA 6Gb/s Solid State Hard Drive £83.99
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel* Kit (CMZ8GX3M2A1866C9) Antec Kúhler H2O 620 CPU Watercooler
OcUK Professional 2.5" to 3.5" SSD Adaptor Plate - Black
My main questions are:
whats the performance gain with dual/tri channel ram?
performance/overclocking gain for the 2500k/2600k
is the water cooling that much better than air.
Any other suggestions?
note: i only need a 64GB SSD for my operating system so that doesnt need to be ammended.
Thanks in advance.
I want this to build it this weekend
CPU
MOBO
RAM
Thanks in advance.
