- 5 Feb 2011
- limerick
upgrade help palit gtx 680
Hi there guys i want to go sli with the gtx 680 , the only thing is i have palit gtx 680 , which as you know take nearly 3 slots.
I will like to ask if anyone here as done something similar with a palit.
In my system i have also a killer 2100 network card and a asus xonar d2x pci that require slot.
Any idea what to do with a 450 £ budget.
My spec is: I7 2600k sandybridge ( i think this will be good for a wile)
Palit jetstream gtx 680 2gb ( second soon , out of the budget of 450
850 psu corsair tx
8 gb corsair xms
cpu wather cooled
Asrock extreme 4 (gen "2") so i suppose upgrade here.
Corsair 650 case ( plenty of space )
Thank you if you can help me out with some idea , i will be ready to sale the network card even do i like it for some reason in my system works, i saw some mobo as it onboard like the gigabyte sniper i think .
Thank you for you help, open to suggestion
850 psu corsair tx
8 gb corsair xms
cpu wather cooled
