Upgrade help
23 Feb 2010
Huddersfield
I'm thinking of buying a R9 270 to replace my failing 5850.
Given the spec of my system;
P6t Deluxe and i7 930, will it be able to handle the new card or will their be major CPU bottlenecks?
Secondly do you think upgrading mobo and CPU to a 4470 will be worthwhile?
Any thoughts would be greats
Thanks
TBH I think a you will be fine with the i7 930 for a bit longer and a 270 shouldn't be held back by it. If push comes to shove you could always OC it.
