Upgrade help.
15 Dec 2011
Hi im looking to upgrade my spec because had it nearly 2 and half years and feel it needs upgrading. im looking too future proof it for gaming and I need it for streaming/youtube videos. the budget isn't too big don't want to spend much that's why I want an upgrade not new build. so as cheap upgrade as possible please not sure the exact amount.
current specs:
intel Core i5-2500K 3.30GHz
Asus GeForce GTX 560 DirectCU 1024MB GDDR5 PCI-Express Graphics Card
Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) HDD
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)
Cooler Master Elite 430 Blue LED Windowed Case - Black
OcUK 22x DVD±RW SATA ReWriter (Black) - OEM
Windows 7 64 bit
Definitely mate, your case is capable of accommodating an even bigger cooler if you wish to spend more. This would allow for a higher overclock whilst keeping temperatures under check.
cheers mate. I am going ahead with that suggestion, was wondering as im on a wireless connection do you know anything about that powerline networking if its any good?
ok mate. jus before I purchase is that gpu compatible with my motherboard and case? oh and one more thing what would you recommend I overclock too thanks.
