Upgrade help
12 Dec 2018
Hi
I got a pc about 16 months ago and was wondering if there’s any way I can upgrade the system ie motherboard or ryzen processor with out having to totally start over from scratch again ? was looking to maybe sli the graphics. Or any other suggestions as when gaming I’m getting frame loses and latency issues all the time . Here’s the original build spec that you did for me .
Any help would be greatly appreciated
Thanks Paul
PCS ENIGMA 6003B BLACK CASE
AMD Ryzen 5 1600 Six Core CPU (3.4GHz-3.6GHz/19MB CACHE/AM4)
ASUS® PRIME A320M-K: Micro-ATX, AM4, USB 3.0, 6GB/s
8GB Corsair VENGEANCE DDR4 2133MHz (2 x 4GB)
6GB NVIDIA GEFORCE GTX 1060 - DVI, HDMI, 3 x DP - GeForce GTX VR Ready! 1TB SEAGATE FIRECUDA 3.5" SSHD - UP TO 5X FASTER THAN HDD!
24x DUAL LAYER DVD WRITER ±R/±RW/RAM
CORSAIR 350W VS SERIESTM VS-350 POWER SUPPLY
1 x 1 Metre UK Power Cable (Kettle Lead)
Super Quiet Titan DragonFly Heatpipe AMD CPU Cooler
STANDARD THERMAL PASTE FOR SUFFICIENT COOLING
ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)
WIRELESS 802.11 AC1200 867Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD
Hi
Thanks Paul
Hi, for the better, a new motherboard with B450 chipset for 80-110 pounds, DDR4 3200 because this is one of the more important parameters in a Ryzen build, and your power supply can be a little bit more powerful than only 350W.
