I'd like to improve my home network, possibly replacing almost everything.
I currently have a BT VDSL modem connecting to a Netgear router, this has a couple of devices connected then there's a cable run to the garage, here there is a switch with another router connected acted as an access point and other devices, then another run to another part of the house with the same configuration again. The other routers are different models and makes.
I did have the same SSID and password on all 3 AP's, but sometimes my phone would stick on one that was out of range, so I changed all the AP's to different names.
The first router has rubbish wifi range, I'm thinking about buying the Asus N66U and maybe 2x N900 AP's. DO you think it would be better having them all the same brand? Or not worth the outlay? I will probably buy the N66U anyway and set the other 2 the same SSID, not sure they will be able to do the same encryption though.
Any advice would be great.
Thanks
Thanks
