Hi I currently have a Dell Dimension 9150 with Pentium 4 D (3.2ghz) 940 dual core.
I have 1.5 gig ddr2 ram. And a dell dxp051 motherboard(ive run numerous benchmarks but still dont know what socket it is. I have recently fitted a Nvidia geforce 7900gs pci express with 512 mb ddr3 graphics mem. Samsung SATA 260 gb h/drive. etc.
I want to upgrade what should I next get?, maybe I should try to overclock the 940?, but as its a Dell I think I need a new motherboard/powersupply?.
But maybe I should just get a new motherboard and a core2duo chip?. But would I need a new case as its a dell?, or would the motherboard I have support the core2duo?.
So many questions!!!
I do hope you can answer them, I cant really give much more info about the system as its at home and Im at my parents. Help would be very appreciated, merry xmas.
p.s your thoughts on if my computer is ok or not as it is, would also be helpful so I know how good it is.
I do hope you can answer them, I cant really give much more info about the system as its at home and Im at my parents. Help would be very appreciated, merry xmas.p.s your thoughts on if my computer is ok or not as it is, would also be helpful so I know how good it is.
