Upgrade Installation Questions
4 Aug 2006
I'm just about to install a new PSU, but I've never done it before. I'm sure it's fairly straight forward, but is there anything I should know? A specific order to plug things up, or anything else I might not be aware of?
A bit noobish I know, but I'd rather be safe.
Straight after that I'll be installng a new GFX card - first one in my PC that will need a molex (AGP). Anything I need to know here? I assume I need to give it it's own power line, not one in series with a drive etc? I'm just guessing though, as I've not done this before either. Again, very noobish, but any tips or advice would really help.
Note where the leads go to then unplug the old PSU, unscrew it and replace it with the new one, connect up all the leads and that should be you good to go. No specific order but do make sure everything is connected. :)
For the graphics card it is best if you can give it a line without any other components on it but don't worry about it too much.
