I had the same feeling but with a q9550 only had it for year and now i have my i7 build, it can't be helped it's an illness![]()
Don't do it! a Q6600 at 3.8Ghz is awesome enough!
i7 would be a pointless spend of lots of money. Think about it... you'll have to buy everything again. Everything. Triple channel RAM is expensive enough without having to think about the expensive chipset on the motherboard, and the most expensive processor on the market currently, unless you get the low spec ones, which will be worse than your 6600.
and many hobbies are ultimately wasteful money wise! This has been nagging at me since last year, suprised I haven't already folded.
Your PC is good enough for now, and that reduced cost is enough to justify it.
Corran don't do it!!!!! think of what else all that money could be spent on. Plus do you really NEED an i7? surely the old q6600 is performing well.
is that what you was after![]()
Since you managed to get your Q6600 to 3.8, it suggests you'd be able to do similar wizardry with an i7.
If the itch won't go, no matter what is said, just give in and get it. You could always tell yourself that you want one, and keep an eye on the weekly offers until a part you want is reducedYour PC is good enough for now, and that reduced cost is enough to justify it.
