I am currently running "OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2(1.9-2.0 Volts-CL 4-4-4-15)"
But i want to upgrade to Win 7 64 bit and OCUK no longer sell this memory. should i try to sell my existing memory and buy 2 new 2X2gb strips? or is there an alternate memory that will run alongide it without causing problems?
For example...((( OCZ Titanium 4GB (2x2GB) Edition DDR2 PC2-6400 Dual Channel )) same latency settings but runs at higher voltage...
I seem to remember i had trouble setting up the memory because the MB default voltage was to high..but i could be wrong..
Any advice thanks guys... Sychnant
any recomendations?
