- 12 Mar 2011
- Rainham, Kent
Currently looking at upgrading my Asrock M3A770DE to a Asus Crosshair IV Formula AMD 890FX Also looking at Upgrading my OCZ Platinum 1333mhz ram to Corsair XMS3 4GB. My questions is will this be worth it? Right now the Highes OC i can get on my 1090T is 3.7GHZ Stable. Will I be able to hit 4.x if I get this upgrade? That is my main goal here. I will be using a few different air cooling techniques and modifications so I am not concerned about temps as of now. Just want to make sure this will be able to give me the bit of boost I am looking for .
Other Specs: HIS HD 5770 oc'd : OCZ StealStream 500w : 1090T :
Will be upgrading the PSU and GPU down the road when I upgrade my monitor. Currently my 5770 runs my monitor maxed out every game I play so is no problem yet. From the looks of it this board will give me the option to upgrade other components down the road.
Also not concerned about waiting for BD as I don't even use this PC to its limits yet just want a bit more OC out if it not really that I need it.
Any help / suggestions is always appreciated and Thanks in advance
