Upgrade Monitor for GTX 670
29 Sep 2004
Wilt of the Shire
Just spent my bonus from work (not a banker) on a GTX 670 and now realise that I maybe should upgrade my monitor to get the most out of the card. I've currently got an Iiyama E2710HDSD which is 1920 x 1080. I only play games and work/surf on the monitor, don't watch any movies - big telly's for that.
So, should I upgrade and if so what to? Just had a quick look and this one seems ok:
Hazro HZ27WC
I don't really want to go any higher price wise.
Cheers.
Personally I'd recommend a 120hz monitor if you're gaming and want the most out of the GTX 670 (you won't notice the higher resolution in games imo), they can be had for a similar price too depending on which one you go for. However for other purposes perhaps a decept IPS monitor in 1440p would suit you like what you pasted :) But you'll take an FPS hit in games by upping the resolution. Perhaps it also depends on what sort of games you play.
Regards,
Stanith
If you are looking to max out games at the 2560x1440 of the Hazro then the 670 just won't cut it as a sole card. Obviously depends what type of games you're into but stuff like BF3 and Metro will struggle.
