Upgrade my PC for Fraps recording
16 Sep 2013
Gloucester
Hi Guys
After asking customer support team and they cannot really help me need help from you guys
I'm really intresting on upgrading my current system to fit my needs .
My Current specs:
Case
COOLERMASTER CM STORM TROOPER - GAMING ENTHUSIAST CASE
Processor (CPU)
Intel® Core™i7 Quad Core Processor i7-3770K (3.5GHz) 8MB Cache
Motherboard
ASUS® MAXIMUS V GENE: M-ATX, INTEL Z77 ROG MOTHERBOARD
Memory (RAM)
16GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (4 x 4GB KIT)
Graphics Card
2x 4GB NVIDIA GEFORCE GTX 680 - 2 DVI, HDMI, DP - 3D Vision Ready
Memory - 1st Hard Disk
120GB INTEL® 330 SERIES SSD, SATA 6 Gb/s (upto 500MB/sR | 450MB/sW)
2nd Hard Disk
2TB 3.5" SATA-III 6GB/s HDD 7200RPM 64MB CACHE
1st DVD/BLU-RAY Drive
24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Power Supply
CORSAIR 850W ENTHUSIAST SERIES™ TX850 V2-80 PLUS® BRONZE (£99)
Processor Cooling
COOLIT ECO II FAT BOY PUSH/PULL CONFIG LIQUID CPU COOLER
Sound Card
ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)
Wireless/Wired Networking
10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
USB Options
6 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
Operating System
Genuine Windows 7 Home Premium 64 Bit - inc DVD & Licence
So to the point
I'm gamer and youtuber as well so my priority is to get the best content as i can and after 6 month i realize that the best recording solution is fraps as its make the best picture quality .
on my current set-up i'm easily can play any game on ultra settings , but issue come when i start recording with fraps as fraps make my pc cry.
So the issue is i need upgrade my setup to be able to play at ultra settings 1080p/120fps (witch i currently can) and record with fraps 60FPS !!! (cannot)
at they moment when i try record record at 60fps my pc start lagging and recorded video is laggy as well
many people b4 told me to lower to medium setting or change resolution - Thats is not solution for me !!!
I need upgrade my system to be able to play mainly Battlefield 3/4 on ultra settings and recording with fraps with 60fps
I try many solutions b4 (capture card,other recording programs) but not even one produce as clear video as fraps . I try look for 1080p/60fps capture card but they go for 800£ up with is expensive for just capture card .
So i wonder if you guys can help me to configure upgrade system
i been looking on new 4 generation i7 extreme edition CPU's and they looks cool , but i think new cpu need new motherboard and there is my dead end .
Can you guys help me ?
Give me some advice and quote for upgrade
Thank you
Have a second SSD for FRAPS to dump the captures to, the slowdown you are seeing is fraps flooding your SATA bus with data. The reason is along the same lines as what drakt mentioned.
You could even get a PCI-e based SSD to avoid saturating the SATA bus, or a PCI-e SATA controller.
Information here regarding data rates.
Uncompressed data rate = color depths * vertical resolution * horizontal resolution * refresh frequency
Examples
24bit @ 1080i @ 30fps :24*1920*1080*30=1.49 Gbps.
24bit @ 1080p @ 60fps :24*1920*1080*60=2.98 Gbit/s.
Goodluck finding an SSD that'll write at those speeds.
TLDR;
Do some research about what you are trying to achieve.
