Upgrade / New Build Advice
30 Oct 2011
Hey guys I'm looking at upgrading my PC soon.
My PC is for gaming and I want to make sure I can run many programs at once, without slow down, or high temps etc.
Current specs that I'm keeping:
Case: Cooler Master HAF 932 Advanced
PSU: Lepa G-Series 900W
GPU: MSI GeForce GTX 580 OC Twin FrozR II
New upgrades that I'm after:
CPU - i7 (I don't know the details of the differences between the processors, what will be best for me, seems obvious to go for the highest clock speed).
Is Intel Core i7-2700K 3.50GHz the best option?
Mobo - Something that can handle my wanted/current specs - I assume 1155 socket, allow for OC'ing, high amount of RAM (8+).
I seen this offer which seems good, but is it recommended? http://www.overclockers.co.uk/showproduct.php?prodid=MB-199-MS
RAM - Not exactly sure on what's best, looking at as much as possible without going too expensive. Maybe 8GB.
CPU Heatsink & Fan : My current fan and heatsink has not gave me the best of results so I need a new one, one that is compatible with an i7 processor. Something to keep the temps low as possible.
Another question I have is; my case has holes for the mobo to be screwed in, but the mobo screws go into other screws which attach to the case. I think these are called pillar screws: shown here: http://images.devshed.com/dh/stories/Building_System_Scratch/scews.jpg
However I have some missing currently meaning I have had to spread the screws across the mobo to attach it, will these come with buying a motherboard? If not where can I find extra ones for my case ?
I'm open to any recommendations or advice. Thanks for any help, I appreciate it.
What programs are you looking at running?
You will need to have a search around the net for stand-offs, Ocuk don't sell them separately.
Do you have a max budget in mind?
Ok, I presume that's what the screws are called. Thanks for the help.
Well the Mobo's and CPU's all seem to be similar priced - around 250 for the CPU and 150-200 for the Mobo. Plus there are often bundles for the RAM too.
I would probably say around £500 for CPU, Mobo, RAM, Fan+Heatsink.
See my build above :)
Edit: and below:
YOUR BASKET
1 x Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £269.99
1 x Gigabyte Z77X-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £112.99
2 x Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (BLS2CP4G3D1609DS1S00CEU) £35.99 (£71.98)
1 x Alpenföhn Matterhorn Pure Edition CPU Cooler (Socket LGA2011/1366/1155/1156/775/ AMD AM3/AM3+/AM2/AM2+/FM1) £29.99
Total : £484.94 (includes shipping : FREE).
Thanks for putting that together!
That definitely looks like something I had in mind.
Do you know what CPU temps I could expect from a build like that. It's just an issue I've had with my current build, and I'm wanting to make sure I'll have nice temps.
No probs :)
Hard to say on the temps, the cooler is excellent for its price, so you should see respectable temps :)
- Also I was wondering how the Heatsink and Fan fits onto the Mobo.
My current fan screws right into the mobo like this: http://www.pacificgeek.com/productimages/xl/DI5-9HDSL-0L-GP-2.jpg
Is it similar, just the pictures of that cooler look quite different to what I've used before. Just making sure I know what to expect when I get it.
Edit: Nevermind, I just watched an installation video on YouTube, I see how it attaches now.
Keep a eye on This Week only which changes every Wednesday, you might get some better deals on memory.
