Hi guys,
I feel my PC need a bit of an upgrade (for Windows 7 possibly in long term, sticking but currently on XP Media Centre at the moment).
The system spec currently is:
AMD Athlon 64 3200 (s939)
1GB DDR400 RAM (2x512)
ATI X850 XT PCI-E graphics card
DFI LANPARTY NF4 Motherboard
A rubbish 120gb IDE HDD.
What I'm interested in is what are my best options for a relatively cheap (£100ish?) upgrade to the system to make it last a little longer?
I was thinking of either getting 2x 1GB sticks of RAM to replace the 2x 512MB and getting a new HDD.
Also, I had thought of getting a better CPU in there, perhaps an X2? I know I'm limited with what type of CPU I can use.
What would you recommend? I tend to use the computer for internet + movies, but I do still play Half-Life 2/source engine based games from time to time.
Thanks,
Dave
Thanks,
Dave
