Upgrade Options
25 Jul 2006
Hello .
Pc Specs :
Intel i4670 k @4.4 ghz
gigabyte z87xd3h
gigabyte r9 270 x
16 gb avexir ram
60gb ssd (samsung)
couple of hdds
1080 p gaming
i want to do another build however the above pc does play everything really well however id like to get a higher resolution monitor for gaming which will stretch the above spec.
Ive got an £1800 budget for the pc including monitor. Is it worth upgrading just for the sake of higher resolution? Would you just get a new monitor and graphics? Alternatively what about an x99 chipset?
Any help much appreciated
Alex
Hi Alex.
I'm not the most knowledgeable person on here but would like to chime in and just say if that was my pc all I would do is buy a bigger ssd (samsung 850 evo 256gb) and buy a gtx 980ti / fury x either of them will power a 4k display.
Hopefully that was of some help !
