- 29 Oct 2002
Hi all,
I'll start by saying my current PC has served me well, but is now a few generations behind and I'm now starting to look at upgrade paths. Budget is TBC, but I'd expect around the £650-£750ish mark, could go higher but would need a solid reason, this would cover CPU + MoBo + Ram.
The current setup is an I5-6600K @ 4.5Ghz, MSI Z170M Mortar, and 32Gb of pc-2400 DDR4, all paired with a 1080Ti. This setup was an upgrade from an I5-760, and proved to be a huge boost, so I'd be aiming for the same sort of performance increase, if it can be done.
I've read up on the 8th & 9th gen Intel, but also have an eye on the 3000 series AMD chips which look like a solid contender to the Intel chips. I'd like to overclock (cos why not??) so Intel would be a "K" chip however I'd not used AMD since the old T-bird chip waaaay back in the day so I'm at a loss of what a decent "mid-range" platform would be, i'd guess something around the Ryzen 5 3600x?
I'd guess that going from 4C/4T to 6-8C/12-16T would offer the biggest boost so what would my rough options be? Oh, forgot to add, Matx max sized board!
I will also note that I've read a lot of the current "spec me" type posts, and have a rough idea of what's what, I'm just after a little extra guidance.
Many thanks!
DB
Many thanks!
DB
