Upgrade or no?
25 Dec 2008
Birmingham
Specs as in sig. Like the Asus GTX760 card as virtually silent, could do with a bit more poke from the GPU at current time in games; what to upgrade to?
GTX 1060 3 gig - Zotac £190 give or take
GTX 780 TI 3 gig £170 from a second hand store
GTX 780 3 gig £135 from second hand store
Or just keep using what I'm using until prices go down a tad. My budget is £200, no access to MM 'cos not enough posts.
Advice please!
1050ti not much better than what I have. The Overclockers 1060 seems ok? well it does to me, despite 3 gig
It's a fair bit better but I would definitely stump up for a 6GB GTX1060. The 3GB version is still a lot faster than a 1050ti but if you plan keeping it as long as you had the 760....worth going for 6GB.
I'd pay £120 top for a Ti look at used gtx 980s can be had for around £170 and once overclocked can still crunch through 1080p and will be a great upgrade from your 760
You could find a second hand 970 4GB for around £120.. Like @pmc25 has advised, don't spend near on £200 for 3GB version 1060 have a search around for a used 6Gb you may have some luck...
