upgrade or not to upgrade St20G5
21 Jul 2005
Wakefield
im on a budget should i try to squeeze more out of my machine buy upgrading the cpu and the ram and GFX ? or should i bin it and start from scratch
spec below
advise is much appreciated
The obvious "option" is to go with a new C2D system, however there's nothing in the way off SFF overclockability for C2D, so the gap isn't going to be as big as it would be with a desktop.
Luckily it also appears to have a PCIe slot, so it might well be worth going for an X1950Pro or X1950XT on the excellent this week only offer. Past that you're going into 8800GTS 640MB territory, and you may find your CPU a bottleneck there.
I'd also recommend picking up another GB of RAM, maybe swap your HDDs for one big one, a Seagate 7200.10 possibly?
im going to star my new system and base it on this board
Abit Fatal1ty FP-IN9 SLI NF650i
going to sell My ST20G5 And Star afresh
