Upgrade or not?
28 Mar 2013
Hello everyone!
I hope you are all well.
About 18 months or so ago I built my first PC (primarily for gaming etc) and I was quite pleased with the way it all turned out.In fact my family could'nt believe I had done it and nor could my workmates at the time!Anyway I am now thinking about upgrading the one I built or even starting another PC build!Based on the components of my current and only build can you advise me whether to upgrade or build?
These are the components of my first build:
Thermaltake V3 Case
AMD Athlon II X2 250 3.0 Ghz CPU
Arctic Cooling Freezer Pro 7
Gigabyte GA MA770-UD3 Motherboard
WD Sata 2 1Tb HDD
Sony DVD Writer
Kingston 8Gb DDR2 Ram
ATI Radeon HD 5500 Series Graphics Card
Storm 600w PSU.
Any and all advice will be gratefully received and thank you for taking time out to read this.:)
Hi and welcome to the forums. If you are gaming on it, I strongly recommend you build another system.
Do you have a rough budget in mind?
If HDD and optical are SATA, keep them. The rest can go the way of the dodo, or resale for a few bucks.
Then it's a budget thing. Typically, a 2500K / 3570K, 650 ti boost 2GB / 7850 2GB, Z77 mobo, 8GB ram, 450W PSU. Your case looks meh, but could save you £50 (else, a Zalman Z9 USB3 / Corsair 200R / 300R, NZXT 210, Bitfenix Shinobi).
