- 11 May 2011
Here is my current pc:
-Sapphire Radeon R9 280X Dual-X OC 3072MB GDDR5 PCI-Express Card
-Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail
-2 x Asus VN247H 24"Widescreen Super Narrow Bezel LED Monitor - Black
-Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard
-Samsung 120GB SSD 840 EVO SATA 6Gbs Basic - (MZ-7TE120BW)
-Aerocool Xpredator X1 Midi Tower Case - Black
-Seagate Barracuda 7200RPM 1TB SATA 6Gbs 64MB Cache - OEM (ST1000DM003) HDD
-SuperFlower Amazon 450W "80 Plus Bronze" Power Supply
-OcUK 24x DVD±RW SATA ReWriter (Black) - OEM
-Raijintek Themis Direct Contact CPU Cooler
-SanDisk SSD PLUS 240 GB up to 520 MB/s Sata III 2.5 inch Internal SSD
-HyperX HX324C11SRK2/16 Savage 16 GB (2 x 8 GB) 2400 MHz DDR3 CL11 UDIMM XMP Memory Module, Red
I'm looking to buy a nice new monitor and upgrade my pc for about £700. Or would people recommend I hold off and spend more later, get an overhaul?
I'm upgrading partly because I'm wanting to use higher graphics settings in my games as it is struggling more often these days. And partly as a corona lock down project as I'm getting bored at home.
If it's really worth spending more on an overhaul in a year or 2 then maybe what would people suggest for a cheap and cheerful upgrade? I'm thinking my current weak points are power supply and graphics card but I'm not so clued up in all this. :s
this ol girls lasted very well but 6 years is a long time (where does it go?). So B550 is where its at? If you could cobble together a £700 pc that would be grand. I could save up for a decent monitor afterwards I suppose. Better to put all the pennies in the tower.
