Hi all,
Need a bit of a helping hand. I bought a 'Titan Supersaurus' from OcUK back around 2010 and haven't upgraded anything since.
It has come to the time where I quite fancy a new setup but am unsure of whether to ditch the current one and buy a whole new system or whether I can just upgrade what I have now. Current specs:
Video Card NVIDIA GeForce GTX 570
Operating System Microsoft Windows 10 (build 10586) 64-bit
Intel Core i5 2500K 3.30GHz
Intel Z77 Chipset
8GB DDR3 1600MHz
1TB HDD
60GB SSD
PC Power & Cooling 600w PSU
DX11 GFX, LG DVD-RW, Asus Xonar DG 5.1, Prolimatech Panther CPU Cooler
My initial plan was to simply upgrade to GPU to a 1070 and throw in 16gb's of RAM but am wondering whether it will be bottlenecked by the other components at all?
Also, I'm looking for a new monitor and have seen that a lot of the ultrawide monitors that are freesync and way less expensive than gsync and there are far more of them to choose from. Could I pop an AMD GPU into my current setup to take advantage of that or am I constricted to Nvidia in some way?
LASTLY (long post, many questions, I can only apologise), my current setup is pretty God damn loud. How easy is it to reduce that with fan replacement's etc or is it more to do with the case itself?
Quick Edit: I'm looking at spending £500 on a new system if need be, otherwise just the cost of a 1070 plus some RAM for upgrades. Budget mainly down to wanting to spend £500 on a b.e.a.utiful monitor
System is also primarily for gaming so with the new monitor looking to achieve some pretty demanding ultrawide, 21:9 gaming on the usual AAA games hence why I'm looking at a 1070
Thanks for any help guys, after typing this up I'm leaning towards just buying a new system and perhaps selling what I can of this for parts rather than trying to upgrade GPU, RAM, fitting new fans etc but would really like to hear some more informed opinions.
Cheers
Intel Z77 Chipset
8GB DDR3 1600MHz
1TB HDD
60GB SSD
Cheers
