Upgrade or wait another year?
14 Sep 2012
Current PC:
Creative Sound Blaster X-Fi Titanium HD Sound Card
BenQ XL2420T 24" TRUE 120Hz 3D x4
Corsair Dominator 16GB (4x4GB) PC3-14900C9 1866MHz Dual/Quad Channel x2 (32GB)
Asus GeForce GTX 680 DirectCU II TOP 2048MB
Intel Core i7-3930K 3.20GHz (Sandybridge-E) Socket LGA2011
Gigabyte X79-UP4 Intel X79
Seagate Barracuda 3TB 7200RPM SATA 6Gb/s 64MB Cache - OEM
Silverstone Strider Plus 750W Modular '80 Plus Silver' Power Supply
OCZ Vertex 4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive x2 (Raid 0)
Corsair Hydro H100 Extreme Performance Liquid CPU Cooler
Antec P280 Super Midi Tower Case
I will be keeping my monitors.
Purpose: I use my Computer for work and leisure All day and every day, I work from home as a Programmer and Day trader.
I would like the emphasis to be CPU/Ram/Storage, Ideally I would like a large capacity drive for just storing, and SSD(s) for OS/Work. (Minimum 1TB SSD, 4GB HDD), I would like to get away from Raid if possible (without loosing any performance compared to this setup).
Graphics should NOT be SLI/Crossfire. I see it as a waste since I don't play too many demanding games, but an upgrade from the 680 preferable but must be able to run 4x screens like the 680, (Currently: 2x DVI, 1x HDMI, 1xDP) however I'm quite happy to move away from the HDMI connector (to just DVI/DP).
I don't overclock, but having the option to do so would be nice. (if needed)
Budget: No Budget, I would like to get the best CPU/Ram/Motherboard combination with speed in mind (with in logical reason).
Will there be any point in upgrading yet or shall I wait until next year?
Still a very strong system, wait.
OC the CPU if you need a bit more grunt.
If you need more GFX power then a GPU upgrade and how about a bigger SSD.
Thanks for the input,
I was looking at getting the Intel 750 1.2TB PCI-E SSD but I don't know if I would be able to use it to its full extent with this system any input on that? (not to mention it's currently out of stock.)
Your CPU is PCI-E2.0 so you will be a tiny bit held back compared to a 3.0 setup, the X99 board you have has plenty of slots that will feed it the 4X lanes it needs without effecting your 16X to your GFX card.
