upgrade path for 32b 2003 to 64bit 2008
28 Sep 2008
Britain
I know that there is no real supported upgrade path. How would you upgrade this server (its DNS and DHCP) without loosing settings?
USMT or similar?
Install DNS on the 2008 server and add it into the zone as a secondary server, then make it SOA for the zone, then take out the old (after telling DHCP to point the clients to the new server)
For DHCP just create a new one with the same scopes and settings etc, set conflict detection to 1 or 2 and then just de-authorise the old one.
Unless you really want to preserve the DB, you can take it over but to be honest on a small implementation then its often not worth the time when it can just re-create itself.
On a big bloke though you'll want to take the DB over. Done it a few times on NT 4 to 2k upgrades but never from 2k3 to 2k8 thus far.
