Upgrade path to take?
9 Jan 2009
Stoke On Trent
Hey there! Little help, My current PC's motherboard USB ports are all becoming very erratic constantly disconnecting and such, coupled with my case USBs not working from day 1 really.
So new case is on the cards either way, But my upgrading can go several ways.
- Stay with the same processor and just replace the motherboard.
- Upgrade both.
- Change from AMD to intel and go down that motherboard/cpu path.
My current spec is,
AMD Phenom II x4 955 @3.2
Asus M4A89GTD PRO Socket AM3
Nvidia GTX460 768MB
4GB (2x2GB) DDR3 PC3-12800C6 1600MHz Dual-Channel
...all in a terrible case.
Just replacing the motherboard is the cheapest solution, but I could part with around £200 for any of the other options if I can give myself a few more years of use or put myself on a longer lasting upgrade path if anyone has any suggestions?
Cheers
I would probably just change the motherboard, then add a SSD, with the new board this will allow you to upgrade to Piledriver at a later date of needed.
I would just swap out the motherboard, that will fix your USB problems. Then maybe get a new CPU if it is on a good weekly in the shop.
