Upgrade Possible?
21 Sep 2006
Hi, I currently have:
AMD 146 @ 3ghz
2Gb Geil Ram
7800GT
Is is possible to upgrade to a conroe If my budget was around £300 - £400? Maybe stretch to £500. I do overclock.
All help will be appreciated.
Thanks
I think this is about the minimum you'd require to get a decent Conroe based system that would offer any noticeable improvement over your current PC. It should also be good for 3ghz+ but is dual core and ought to be faster overall.
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM £97.99
(£115.14) £97.99
(£115.14)
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard £89.99
(£105.74) £89.99
(£105.74)
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) £169.99
(£199.74) £169.99
(£199.74)
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) £14.99
(£17.61) £14.99
(£17.61)
Sub Total : £372.96
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.25
Vat : £66.71
Total : £447.92
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail £109.99 (£129.24)
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard
£89.99 (£105.74)
GeIL 2GB (2x1GB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX22GB5300DC) £139.99 (£164.49)
Sub Total : £339.97
Vat : £60.94
Total : £409.16
Gah I'm half asleep, went for retail and didn't think about 3rd party cooler. Go with Semi-Pros spec :)
It is as good for gaming as any CPU/motherboard/Ram will be pretty much, it should be faster than your current system but since the graphics card is unchanged it might not make all that noticeable a difference. There is definitely good potential to overclock though.
