Upgrade Priority - GFX or CPU?
28 Jun 2005
Below's my current setup. It's showing it's age but I haven't got the money right now to replace the whole thing so it's going to have to be the GFX or the CPU right now. I don't know if this graphics card is still decent enough to carry on a while longer if I threw in a quad-core? Or can I make do with the clocked C2D and pick up a newer card? Budget's around £250. Will be playing BFBC2 and APB. Playing APB with Low settings and the framerate drops below thirty constantly. Any advice appreciated.
BFG GeForce 8800 GTX OC 768MB GDDR3 HDTV/Dual DVI (PCI-Express)
GeIL 2GB (2x1GB) DDR2 PC2-6400C4 800MHz Ultra Low Latency Dual Channel
OCZ Gold Edition 4GB (2x2GB) PC2-6400C5 Dual Channel Series
Thermaltake VD4000SWA LCS Aluminium Kandalf Full Tower
Intel Core 2 Duo E6600 "LGA775 Conroe" 2.40GHz (1066FSB) *oc'd to 3Ghz*
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard
you can afford a second hand Q6600, which if you o/c to around 3ghz will last for a few years, cost is about £80.
and a ATI 5830 for £160.
whats with the strange ram amounts? you need to populate the ram slots with the same capacity as well as speed ram sticks to get dual channel
