I have been given the task of upgrading my granda's computer (the general request of can you make it faster?). He is currently running an Dimension 3100c with a Celeron 346 3.06Ghz and 2x512mb of 266mhz cas4 ddr2 (only 2 slots).
I was thinking an upgrade to 2gb (max supported) 533mhz ddr2, would this be much of a noticible upgrade?
Also was thinking about a processor upgrade but I can't seem to find a supported processor list. All the information i can get is "Intel® Pentium® or Celeron® processors". New bios's also shows:
"The following changes have been made to BIOS rev A01 to create A02:
1. Add support for new processor."
Do you think this would support the newer pentium 4 dual cores? This should be a nice upgrade for a resonable amount of money.
Cheers guys!
Cheers guys!
