Hi all, I finally got the below items which arrived today. I want to start the upgrade but just wanted to check the best method for doing this?
1 x Gigabyte Z97X-UD3H-BK - Devil's Canyon Core i7 4790K CPU & Motherboard Bundle **£15 Saving + Gigabyte Free Upgrade + £30 Intel Cashback ** £397.98
1 x Avexir Golden Blitz 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (AVD3U24001008G-2BZ1SE) £139.99
Previously I have just done a rebuild of my OS drive and re-installed everything, but I was wondering if I uninstalled all the mobo drivers and then did the swap would it work? The Gfx card is the same for the drivers will still be valid along with the Nvidia and AMD chipset and the SSD will be set up on the PCI through the AHCI setting in BIOS (As the IBIS has its on 20Gb card).
Am I going to get BSOD issues because of the change in mobo and if I do shall I just go for the re-install from scratch?
Advice welcome.
Advice welcome.
