Upgrade Q6600 stock cooler
14 Jul 2014
So I donated an old system to a friend which was a Intel Q6600 on a Asus P5N-E SLI. It was running really well for a while but now it seems to be crashing due to high temps.
In Windows, just after a boot, the 4 cores seems to be between 48C and 53C. And if he runs anything CPU hungry the temps quickly climb to around 60C and the system locks up.
I have bought some new thermal paste which I was going to apply but i was thinking that maybe a better cooler might be better. I was looking a:
My basket at Overclockers UK:
Total: £24.01
(includes shipping: £6.02)
The Q6600 is quite a hot chip and has 105 TDP. The above cooler has 130 TDP.
Does anyone have any thoughts/advice? If the CPU is on the way out, what are my options to replace it with?
Thanks
No Thermalight TRUE on ebay? From what i remember when i had the same combon the G0 revision q6600 plus the thermalight with a noiseblocker 120 pwm fan i had really good temps 50 C in full stress.
I had a Q6600 back in the day and those temps are perfectly normal. 60C under load is not a problem, as others have said I don't think that temperatures are the issues here. It could be RAM, PSU or MB.
Wasn't the P5N-E SLI buggy as hell? I had a Q6600 overclocked to 3.8Ghz and never had any problems even when temps were higher than 60 degrees.
OK, thanks for all the advice. I'll inspect the board while I'm re-applying the thermal paste.
Any thoughts on replacing the Q6600 with a Q9550 as a cheap upgrade?
