Hi, I'm planning to either upgrade or replace my pc sometime this year and I can't decide if i should build a new system from scratch or just upgrade.
My budget will be around £1000 but would prefer to spend less if possible.
Current specs are:
Processor: Intel Core i7 920 overclocked at 3.4
Motherboard: Gigabyte EX58 UD3R
RAM: 6gb triple channel
PSU: Corsair 650w TX
Graphics: ATI XFX 5870(got this recently, pc came with a 4850)
Cooler: Akasa Nero(I think, could be wrong)
Hard Drive: Samsung 1tb
DVD Drive: Samsung 22x
Case: Coolermaster Elite 335(It might not be the exact case but it's a similar model)
It's main use is for gaming and i'd like to be able to run recent and also future games on max settings or as close as possible.
Also some questions.
I've been having some problems with the cpu recently, i noticed when i run prime95 my core temps go up to around 80-90 degrees at max load. Is this too hot? In certain games the cpu runs at 100% so i'm afraid it will overheat.
The PC is an overclocked bundle that i bought from here a few years ago and i havent touched any of the settings for overclocking so it should be running at stable temperatures.
Would a better cooler fix that and possibly a better case? as i feel the airflow in my current one isnt very good.
Current specs are:
