Hey guys
I'm looking at upgrading and was hoping you guys might be able to help me with some advice.
My current system is:
AMD Phenom II X2 Dual Core 555 3.20GHz Black Edition (Socket AM3) with the extra 2 cores unlocked and clocked to 3.8ghz
Patriot Viper 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit
Corsair CX 600W ATX Power Supply
ASRock M3A770DE AMD 770 (Socket AM3) DDR3 Motherboard
XFX ATI Radeon HD 5750 XXX 1024MB GDDR5 PCI-Express Graphics Card 800mhz clock speed
WDC 250gb HDD & a 1tb Seagate HDD
Antec 300 Three Hundred Ultimate Gaming Case
Samsung Syncmaster 920N 19" monitor
I only use it for gaming (mostly MMOs) and is plenty for WoW but when I played RIFT and SWToR I had to turn the graphics down to get a decent FPS. As GW2 is on the horizon I am looking to upgrade a bit so I can play it properly.
So far I'm looking at getting:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-030-C3 £184.99
http://www.overclockers.co.uk/showproduct.php?prodid=MO-062-AC £99.95
I looked at a couple of GPUs around that price bracket and the clock speed on this one was a little lower but it has more processing cores - is this a good trade off or do I need to look for one with a higher clock speed?
These parts I'm definitely upgrading. An SSD would be a great improvement but I would need a new mobo for that so that may come later. Possibly looking at http://www.overclockers.co.uk/showproduct.php?prodid=MB-501-AS with a Samsung 830.
Budget-wise I'm looking at about £300 for now for the GPU and monitor which I'm thinking is enough to play GW2 on good graphics. With the mobo above I was thinking if I get that it would last me for a while if I decide to get a better CPU/memory later on.
What do you guys think? Any help on this is greatly appreciated.
Thanks in advance,
Yazudave
Thanks in advance,
Yazudave
