Upgrade Recommendation - Budget £300
22 Jul 2007
Sheffield
Hello everyone
I'm posting to try to get some recommendations on an upgrade path for a friend of mine.
He currently has a....
Processor
2.60 gigahertz Intel Pentium Dual-Core
2048 kilobyte secondary memory cache
64 kilobyte primary memory cache
Motherboard
ASUSTeK Computer INC. P5KPL-SE x.0x
RAM
4096 Megabytes Usable Installed Memory
GPU
ATI Radeon HD 3400 Series
He's got an ok case, PSU (might need to be replaced depending on power requirements of new kit), keyboard, mouse, monitor (720p) and a SSD.
The PC is working great for general computing and Minecraft but he wants to play DayZ and I don't think this configuration is going to cut it?
The budget is £300 right now and he may put more money into it over the coming year.
I first looked at GPUs but then I wondered if the processor will just bottleneck the system?
So the question is, what would you recommend he spends £300 upgrading to get Dayz (stand alone) running well at 720p?
Any help is appreciated, thanks guys!
To be honest on that budgets its going to be a complete pig to upgrade. You're not going to get a cpu, mem and mobo + suitable graphics for £300
A quick build, sell the bf2 code to bring it around £300
YOUR BASKET
1 x Gigabyte Radeon R9 270X WindForce 3X OC 2048MB GDDR5 PCI-Express Graphics Card with BattleField 4 PC Game Included £161.99
1 x AMD Piledriver FX-4 Quad Core 4300 3.80GHz (Socket AM3+) Processor - Retail £79.99
1 x Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit (KHX1333C9D3B1K2/4G) £37.99
1 x MSI 760GM-P23 FX AMD 760G (Socket AM3+) DDR3 Micro-ATX Motherboard £35.99
Total : £325.56 (includes shipping : £8.00).
The AMD APUs really are the goto option on a low budget. With the new ones (Kaveri) due in Jan I think he'd be better off waiting till after crimbo and weigh his options up then.
YOUR BASKET
i second this, about the best it's gonna get for ~£300, you'll need to check power requirements, and if he gets some more money later on id personally suggest a moderate cpu overclock and buying an aftermarket cooler (might set him back a further £25-30)
YOUR BASKET
He says he's going to go for this setup. Thanks everyone for your feedback, these forums (you guys) are really helpful.
