Upgrade/Sidegrade From a 280x Dilemma
4 Jan 2004
Finally, Swindon
Blimey, last time I posted in here was when I got a 9800Pro!
Specs are as my signature, and looking for some advice/insight. Bear in mind I'm a tight****
The problem I have is that everytime I do anything mildly graphics intensive, the fans spin up and the case fan goes into overdrive. I guess stuffing a 250w card into am m-itx case is going to cause heat problems no matter what. It's only a recent issue since I ran the card for years with the side off the case
Also, I've always had reservations about the strain of the card on the power supply. It's rated at 250w and the PSU is 500w.
The solution seems to be to get a lower TDP card - graphics horsepower is not really an issue for me, but an upgarde would obviously be nice
Ideally something like a compact 1060 would fit the bill (120w TDP) but they seem to be as rare as hen's teeth, so sourcing one from the MM is unlikely, and they ain't too cheap either. I guess the compact element was attractive as well since the case is a bit small, so it's logical to get a small card. However, that's not a unsurmountable problem since the 280x is ~297mm long
I then saw a 570 itx on the MM, but that went really quickly as well (150w)
So the I started looking at full size 570s and even some cheap 580s - a 580 went for <£100 in the MM a few days ago. I think they are 185w
So I'm mulling all this over and then see this:
https://www.overclockers.co.uk/giga...ddr5-pci-express-graphics-card-gx-18f-gi.html
With a 3 year guarantee I get a bit more comfort over longevity
Now I'm thinking I'm all over the place and don't really know what I want. Help!
