I'm upgrading my aging 939 setup, and the new spec is below, I'm keeping everything else.
I want to stick with AMD and Quad Core, so it is more advice on the other bits.
Any other sggestions would be welcome.
Am I right in thinking theat the AMD's only support 1066 memory in 2 slots, ie if I got another set of that ram, I'd have to run the RAM slower?
Is that the best RAM, for the price, I did have a look an it apears to be a bargain, is there a reason for this?
Would that cooler fit in an Antec 300? Also is that the best Cooler in the price range? I did look at the TRUE but it doesn't come with a fan for the same price. Is there any others people would recommend, and the same with the TIM cleaner and Thermal compound, are there any better that are cheaper. As I want to keep the cost down if possible.
Thanks, Any help would be greatly appreciated.
