- 13 Jan 2004
- South East
Hi all, just after a quick sanity check please
I'm looking to upgrade my PC, primary use is photo editing, my current machine is good for this, but it does struggle a bit with Lightroom and CS5 open at the same time. I've just got a new camera and the larger RAW file sizes are raping my machine.
Sooooo, I want to upgrade with the following bits:
I will be carrying over a 4870 1gb, whilst I do game a bit, not enough to justify a new GFX card, and my current rig runs everything I play fine already anyway.
My main question is about the RAM. Is that the right speed/type for this i5 setup? I would like to OC the CPU, but nothing ridiculous.
Second question, I have a CPU cooler on my E8400 like this one - http://www.overclockers.co.uk/showproduct.php?prodid=HS-010-NC&groupid=701&catid=57&subcat=1395
I'm not sure if that's the actual one I have, but will this work on the i5 CPU? If so, will I need to find the original box to get an adapter? If so, this could be a problem as I might not be able to find it
Any glaringly obvious compatibility issues with the above spec?
Thanks
Thanks
