upgrade spec check plz
27 Dec 2006
Dark Forest
hi @ll
I play games and surf web @ 1900x1200, some games starting to struggle, think it may be my dual core
existing spec
- Intel e8600 @4.5ghz
- noctua cpu cooler (don't remember name)
- Asus Maximus Formula P47 board
- 8gb corsair ram (800mhz)
- Gigabyte GTX 670 OC Winforce
- Samsung 840 ssd (240gb) + WD caviar green 1tb
- Corsair HX1000watt psu
- win 8.1 64bit
- no wifi since I use wired connections ;)
thinking of upgrading mobo, ram, cpu
- I like black color of gygabite but used to Asus mobo (I am familiar w/ their boards), how does gigabyte bios/driver updates compare? http://www.overclockers.co.uk/showproduct.php?prodid=BU-012-GI&groupid=701&catid=6&subcat=2858
- I am interested in AOI WC kit since the air CPU coolers are massive and dust magnets - are the AOI WC loud (pump/fans)? does water need replacement?
- I added a new case for WC kit since my current case doesn't have the room - also seems like dust filters are easily accessible - I smoke so I need to clean dust regularly
- I only put in 8gb of ram, is 2400mhz overkill? any reason for 16gb?
- I didn't upgrade GFX card since on paper it should be able to handle the games @ current resolution - am I wrong? or instead of upgrading cpu/mobo should I just get a GTX 970?
Thx for help
Nothing wrong with Z97 and Gigabyte BIOS, same drivers too as you uise Intel chipset, Nvidia/AMD GFX drivers, realtek audio etc.
The water doesnt need replacing, they are sealed for life.
8Gb is fine for gaming, if you edit videos etc then go for 16GB.
YOUR BASKET
1 x gigabyte z97x-gaming 7 - devils canyon core i7 4790k cpu & motherboard bundle **£25 saving** £363.98
1 x corsair hydro h110 280mm high performance liquid cpu cooler (cw-9060014-ww) £91.99
1 x corsair hydro h105 extreme performance liquid cpu cooler (cw-9060016-ww ) £89.99
1 x cooler master nepton 240m aio cooling solution £79.99
1 x kingston hyperx savage red 8gb (2x4gb) ddr3 pc3-19200c11 2400mhz dual channel kit (hx324c11srk2/8) £62.99
1 x teamgroup vulcan red 8gb (2x4gb) ddr3 pc3-19200c11 2400mhz dual channel kit (tlred38g2400hc11cdc01) £56.99
total : £755.53 (includes shipping : £8.00).
a choice of ram
a choice of three aio coolers, the h105 has a thicker rad, the h110 is wider, the coolermaster is newer.
£32.50 cashback - http://www.gigabytenordic.com/uk/intel_z97-x99_promotion/index.html
