upgrade spec
21 Oct 2002
I am completely out of touch with tech at the moment, used to be really into it - so i seek your help.
Current spec
Shuttle SN41G2
512mb 2700 ram
Athlon XP 1700 :eek: :eek:
300gb harddisk. +200gb external for backups (sync toy is brilliant!)
R9700
Monitor - syncmaster 171p
+ spare Socket a XP3200 to sell.
I mainly use it for image editing (CS2) and the odd game (although only PES 6).
Now considering my budget is 650 tops!!! What would you spec for an upgrade? For Sanity's sake i will need a bigger monitor. You can expand the budget if you include conservative prices i will get for the above when i attempt to sell it.
Appreciated any suggestions
OcUK Value Hanns-G HW191D 19" Widescreen LCD Monitor - Silver
http://www.overclockers.co.uk/showproduct.php?prodid=MO-017-OK
£143.34 inc VAT
___
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-061-GI
£82.24 inc VAT
___
Intel Core 2 DUO E4300 "LGA775 Allendale" 1.80GHz (800FSB) - Retail
http://www.overclockers.co.uk/showproduct.php?prodid=CP-142-IN
£117.49 inc VAT
___
OCZ ModStream 450w ATX2.2 Power Supply
http://www.overclockers.co.uk/showproduct.php?prodid=CA-016-OC
£46.99 inc VAT
___
OcUK 2GB (2x1GB) PC2-6400 800MHz DDR2 Dual Channel Kit
http://www.overclockers.co.uk/showproduct.php?prodid=MY-010-OK
£145.69 inc VAT
___
BFG GeForce 7600 GT OC 256MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
http://www.overclockers.co.uk/showproduct.php?prodid=GX-019-BG
£82.24 inc VAT
___
Lian-Li PC-7 PLUS Aluminium Midi-Tower Case - Black
http://www.overclockers.co.uk/showproduct.php?prodid=CA-054-LL
£54.04 inc VAT
___
Seagate Barracuda 7200.9 160GB ST3160811AS SATA-II 8MB Cache - OEM
http://www.overclockers.co.uk/showproduct.php?prodid=HD-093-SE
£41.11 inc VAT
___
£713.14 inc VAT.
It's a little overbudget but it should last you a while, this motherboard has only 1 IDE socket and i'm assuming that you current hard drive is IDE, also assuming that your CD \ DVD drive is IDE, if your hard drive is SATA then you wont need a new hd.
Wondering what everyone else thinks of this.
Interesting - I thought i wouldnt need a new hardrive, but if newer motherboards have only one IDE connector i may need to go that way.
Would the monitor be good enough for image editing?
