Upgrade specs
25 Sep 2007
Hertfordshire
Hi guys
After a little advice as I've not been on here in a little while and lost touch a little as where to go next with my system. Hopefully over next couple of months ill gain around £300 and was after a some advice as to what to buy next.
Below is my PC spec which i built nearly two years ago which is used mainly for gaming.
I have a 24 inch dell true colour monitor which I'm more than happy with.
Intel Core 2 Quad Q9550 Processor
Asus P5Q-E Intel P45 Mobo
Gainward ATI Radeon HD 4870 512mb Golden Sample
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU
Samsung SpinPoint F1 640GB SATA-II 16MB Cache
OCZ 4GB (2x2GB) PC2-6400C5 800MHz SLI-Ready Edition Low Latency Dual Channel DDR2
Cheers
Matt
GTX 460 and an SSD? Depends how soon you have the money though, if you're not buying for 3 months then the new AMD graphics cards might be out.
Oh and a Titan Fenrir Evo if you don't already have a CPU cooler.
Get a decent cooler if you have'nt got one and clock that Quad if you have'nt already done so. It's a good combination and should easily hit at least 3.6Ghz.
I have an arctic freezer extreme, definatley going to be over clocking when I sort the case cooling out. I'm on vista aswell so might consider installing a copy of windows 7 on an SSD. Should be a decent upgrade? Gpu will have to wait unfortunately as funds won't really allow this yet.
